Going Carburetor
Going Carburetor
I seen a few people talking about doing a carburetor on their lt1. I figured I would share my info on how I did it. I will still be running the computer for the opti. Im going to run vacuum to the map to control the timing. Heres a few pics, should be done tomorrow. Just have to do the throttle cable and run the fuel lines.
Gm lt1 intake with arp bolts I used a 1 3/8 expandable freeze plug to block off the distributor
Holley 750 HP
Aeromotive Universal Bypass Regulator
-8 fuel line, an fittings, fuel rail fitting adapters so I can still use my factory fuel lines
Fi gone, carb on
Holley 750 HP
Fi gone, carb on
How are you planning to get an air filter on it? Looks like you'll need to get an adjustable jet kit as removing the rear bowl will be a job.
Next time you have the fuel tank down, get a 13 pound fuel pump from an old throttle body injected 454 in there.
Al
Al
I plan to trim a little more to try and fit one on. If I cant Im not sure yet. Im going to pull the tank and sump it later, just didnt have the spare cash to do it now.
