Aeromotive Fuel Pump kit
Old 04-17-2011, 03:32 PM
Big Bad Bud's Avatar
Default Aeromotive Fuel Pump kit
Anyone use this Aeromotive fuel pump kit?
http://www.summitracing.com/parts/AEI-17102/
I know its probably over kill but was just wanting to see if anyone has used it and how hard is it to install?
Old 04-17-2011, 03:41 PM
RamAir95TA's Avatar
There's absolutely no need for all of that. It would be a completely wasted expense, especially at your power level.
Old 04-17-2011, 04:04 PM
Thanks for your input! I know its over kill but Is there an alternative to the in-tank setup? I want to get everything outside of the tank for ease of access. I am also going to turbocharge it soon so was looking for a more reliable fuel delivery.
Old 04-17-2011, 08:50 PM
LS1TECH Sponsor
Lonnies Performance's Avatar
Feel free to give me a call. I'll be glad to help you out.
Lots of things to keep in mind when designing a high powered street fuel system.
Old 04-17-2011, 11:53 PM
Moderator
BizZzatch350's Avatar
I would call Lonnie, he's an honest guy and cares more about setting some thing up that is right for the set up rather than selling you parts. He's also been around these cars for ever.
Old 04-18-2011, 08:34 AM
quik95lt1's Avatar
i am running a modified version of this on my car.......i run -12an from my tank through a 100 micron filter then into the a1000 pump then -8 out of the pump through a 10micron filter up to the rails where they split into two -6an's.......then into the aeromotive compact efi regulator and a -6an back for a return.........
the reason i did this was one like you said so i dont have to deal with an intank pump and two i was loosing fuel pressure at high rpm with the 255........the system would be overkill for you at this point but if FI is in your future its a good idea....
Quick Reply: Aeromotive Fuel Pump kit
