Alternator solution for tall valve covers
I have these valve covers on my 383:
http://www.summitracing.com/parts/PRO-141-131/?rtype=10
I thought I would just have to grind the little ear off the back of the alternator to get it to fit, but I actually had to grind a ton off the case. It worked for a little while, but I was afraid that it would kill my alternator and sure enough it did.
So what can I do to get the alternator to fit? Are there are that have a smaller case? Or any kind of way to relocate the alternator a little higher? Keep in mind I don't want to ditch my AC and I can't use the madman kit because I'm going to have a supercharger. I also don't want to use different valve covers if I can help it.
Loosening the alt casing bolts and rotating them slightly also helps from what I here. I have the same covers and only ground on the alt and they fit fine. There may be a difference in alt from 93-95 though.
I did the same thing, however, over time, I found that those VCs would't hold tension on the gaskets, and start seeping oil. I'd snug them, they'd loosen. I'd snug them, they'd loosen. After a while, I noticed that the tops were "sagging", since they don't have any internal bracing......
need your help asap
Im having same problem and I have the same engine you have with the tall valves , were did you get that alternator from? I looked everywhere for smaller one
