Pulling Codes on a 95 Z28
I have a 95 Z28 and I am trying to figure out how to pull its codes when the check engine light is on. I know it has OBD1 but it has an OBD2 connector. How do I pull codes on it?
Actron CP9145 is used by many 1995 people.
...and probably won't work, since most at that price are just a glorified paper clip that shorts the pins to read the code with the SES light (which won't work past 1993).
You use an OBD-I scanner with the correct adapter cable or adapt a 12 pin cable like this. Or you can use diagnostic software, PC and an adapter cable.
Al
