Dynaspark Opti any good.
Hey guys after some good news I may be just having to buy a new optispark. Anyways since my brand new GM unit from over a year ago has seemed to take a dump I was thinking of paying a little bit more if it will last a bit longer. Anyways I was wondering if anyone had bought the Dynaspark Opti. Since I am in way over budget on the car I might *** well keep going. So is that a good way to go or should i get another gm one or msd?
MSD - absolutely not. It provides zero benefit over a stock AC Delco optispark and is over $100 more. Maybe on a non-vented setup it would be worth it, but on an already-vented setup, no.
There have been several threads about the Dynaspark lately. Read carefully, then draw your own conclusions.
Also, before you go blaming the opti I would check on things like the optispark harness, coil, etc., before you spend money you possibly didn't have to.
hrm looks like ill got to another gm unit. May tear apart mine and see if anything is wrong with it. Btw coil is good, even tested with my brothers good one off his car.
