ARP main stud torque question
i feel stupid but i cant remember(lost the sheet) what the torque spec is for my main studs ARP-234-5501 if anyone knows please let me know! i also am using the arp grease as well which i know makes it lower.
screw in studs hand tight only! ,lube threads ,washers and nutz with ultra torque fastener lube, torque caps in recommended original sequence in three steps to 80ft lbs, tighten windage tray nuts to 30ft lbs the estimated height from top of main cap to mounting surface for windage tray on the underside of nut is 1.875"
