Water pump seal
Water pump seal
So I pulled the classic move as it sounds many other have, but I tore the seal that goes on the water pump drive on the first go around. Now I ordered the tool, will go get a new seal this weekend and try and attempt this the "right way". Anyone have any suggestions or tips so I don't have to go round 3? This seal is supposed to go on dry correct?
Not too bad, paid $15 for the tool, I tried a sharpie cap? Maybe I didn't have the right size though. I just don't want to tear another seal and then be down another $10 in seals. I figure the $15 could save me an endless path of seals...
I put it in a ziploc to keep it dry and then put that in warm water to help soften it.
I have used a deep socket out of the toolbox as my install tool.
Make sure not to fold the inner seal outward.
In the same area and addressing another seal in the kit I boil the damper hub to warm it prior to installation. By boiling it you get it hot but not so hot you could damage it's seal. No need to try to keep it dry as at 212degrees it drys fast once removed from the pot.
the little circle seal thats pressed into the timing cover?
ive put 3 rebuilt lt1s together and put syl-glyde on the hub and water pump drive seal never had any issues with leaking or tearing
