need some gasket pt numbers/links
looking for a nice stiff leak free gasket for my oil pan and a front timing cover set for the 96. im blocking off the water pump outlet so thats not important but i need the seals for the opti, timing cover, and crank. im guessing im going to want to go gm for that kit.
part numbers or links?
shbox posted these for me the other night
1995-1997 front cover opti seal 12552428
1993-1997 front cover crank seal 10128316
1993-1997 front cover water pump seal 10217886
1993-1997 front cover gasket 10128293
1993-1997 water pump gasket (2) 10128343
1993-1997 water pump drive shaft o-ring (2) 12553792
1995-1997 optispark o-ring (2) 10474278
FelPrro timing cover gasket kit # 45956 at most auto parts stores for about $10 has all the gaskets/seals listed above. FelPro also makes a pan gasket they should have for around $25
