flexplate, converter bolts part#
Old 05-28-2011, 04:51 PM
C5042081's Avatar
Default flexplate, converter bolts part#
Well my stock flexplate took a crap, cracked and 2 of the 3 converter holes were about 1/2" opened.
Is there any brands out there other then TCI?
Also would anyone know if the thickness of the flexplate is same as stock? and which converter bolts would works with the tci.
fyi Trans is a 4l60e using a yank ss4000
Old 05-28-2011, 05:54 PM
itSSlowZ28's Avatar
i believe advance auto keeps stock replacement bolts on the shelf in a pack of 3
Old 05-28-2011, 06:16 PM
Jake_the_Snake's Avatar
bolts- http://www.summitracing.com/parts/ARP-200-2906/
flexplate- http://www.summitracing.com/parts/TCI-399173/
there are brands other than tci, but from what i can gather, tci is the best. i wouldnt go with a stocker, especially with such a high stall.
Old 05-28-2011, 07:04 PM
C5042081's Avatar
sweet thx ill check them out, ya the stock flexplate only lasted a few hundred miles after the stall was installed...kicking my self for not spending the extra 100 at the time
woould you think i need longer bolts going into the stall since the tci is a tad thicker?
Old 05-28-2011, 10:02 PM
dont think i did. put around 10k on it so far, no problems
