Walbro 255 PSI #s?
Walbro 255 PSI #s?
Just got my walbro 255 pump in with the racetronix hotwire kit and i slapped the fuel pressure gauge on just to be sure everything is working like it should. It was readying 40-45psi at idle and as i cracked the throttle. Should these kits be pumping out more psi then a stock pump?
If you need/want more pressure you will need an aftermarket FPR and a tune to adjust to the increased pressure
Stock pump hose inside actually split causing the pump to overwork itself and eventually crapped out. I had the walbro and hotwire kit purchased knowing that i would have to eventually have to use it. Just curious is all and makes complete sence with why the numbers are the same as what stock should be with a stock fpr. Thanks for the help!
