transmission gurus come in got a Q
Old 07-13-2011, 08:40 PM
saylorZ28's Avatar
Default transmission gurus come in got a Q
what is the plug in the side of the driver side of the 4l60 for ....? can it be used for my tranny gauge? thanks for the info
Old 07-14-2011, 12:52 AM
93Z2871805's Avatar
4l60/700r4 - lock-up
4l60e - lock-up and I think it interfaces with the PCM as well as your NSS relay
The one in the tailshaft is your speed sensor
I'm not a 100% on the 4L60E as it may be a little different in that way other than the electronic valve body.
Old 07-14-2011, 07:12 PM
saylorZ28's Avatar
its not a electric plug it is a screw in plug ... i was wondering if i can put my sensor in there
Old 07-15-2011, 06:46 AM
93v8clone's Avatar
its a test port for pressure . yes u can put a tranny pressure gauge in it and tie in a temp gauge inline butt your better off doing it in a cooler line or tapping the trans pan
Old 07-15-2011, 07:35 AM
Mystery Bird's Avatar
I put mine in the pan. Welded a bung for it to screw into. It also doubles as a drain plug.
Old 07-15-2011, 08:25 AM
96lt4c4's Avatar
The pan is the best place for your gage sensor.
