boosted lt1 missing problem
Old 07-16-2011, 11:38 AM
detroit_903's Avatar
Default boosted lt1 missing problem
been having a really bad miss latley. replaced almost everything... noticed that 2 out of the 8 plugs are fouled out really bad really wet. the rest of the 6 are dry... did a compression check and everything is perfect in all cylinders. What could the problem... Maybee injectors bad?? or ----
Old 07-16-2011, 11:43 AM
pro94lt's Avatar
valve seals?
Old 07-16-2011, 12:30 PM
Originally Posted by pro94lt
valve seals?
those are good
Old 07-16-2011, 12:55 PM
NoMoreLS1's Avatar
Smile
What was the gap like on the plugs? What type of plugs? Perhaps the gap has closed up and decreased the spark causing a wet plugs.
Old 07-16-2011, 06:41 PM
boostedlt1's Avatar
which two plugs were fouled?
Old 07-16-2011, 07:32 PM
boosted LT1's Avatar
Stock LT1 ignition often have trouble ~7 psi.
I have run an MSD box on 4 boosted LT1s and have had no problems to ~20 psi. I use autolite I think 106 (whatever they call for stock) and run .030 - 035" gap
Good luck
Old 07-17-2011, 12:48 PM
05HD's Avatar
A little bit of info would be helpful here...
What 2 plugs?
Did you change them and it did it again?
Did you change the wires for those plugs?
Swap injectors to different cylinders and see if the fouling follows?
Quick Reply: boosted lt1 missing problem
