204 valves??
well i sent a set off to the machine shop for the usuall valve job the guy doing the heads said that he could up the size of the valves to 204's.Ive seen where AFI and LE only go to 202's.was getting some input before I unknowingly f up a good set of head's
overkill, not to mention valve shrouding and that I don't think thats possible in stock castings anyways, 2.00 is the biggest you can go in stock castings w/o modifying anything, 2.02's need to be back cut to seat properly.
