Fuel injectors?
Fuel injectors?
So I currently have 36 lb/hr Siemens Deka injectors. It appears a few of them are leaking, as the car takes forever to crank and I need to give some throttle input, runs like garbage at lower RPMS and part throttle, reeks of unburnt fuel and will keep idling without missing a beat as I unplug the fuel injectors. Also when I turn the key and it primes? Yeah it goes from 50 psi to 0 psi in less than 20 seconds.
So I think I heard the red tops were redesigned? Are these them? Is this what I want? I am assuming they are enough for a CC503 car? Looking at replacing all my injectors. I also have EFI Live sitting here so I can adjust for the change in rating. Thanks!
Edit: Looked at the heights, the ones I linked are taller than results for LT1 fuel injectors? I guess I need recommendations. Or know if the ones I linked will work without issue despite them being a bit taller. I could see that being an issue with a fuel rail that gets bolted down.
