not starting, any help plz
Ok I just put my motor back together due to a blown head gasket, to make the story short evrything works fine except my ignition wire going to my starter am not getting voltage. I check all fuses everything seems to be fine all the wires including the battery wires. Any ideas? Thanks guys.
Well if you really have checked all the wires, then I would have to assume that something isnt hooked back up properly or that ignition wire is shot. I would double and even triple check every wire under the hood that has to do with ignition or fire. Electrical problems are always a PITA.
