Starting problems
Starting problems
Alright .... Every now and then my car wont start. Ill hear the starter clicking and thats it. I had the alternator checked and it was fine and I bought a new optima battery and it still wont start every once and a while. What could cause this....Im at the point where I just want to start replacing everything, but I dont want to start in the wrong area. Any ideas? Help? Thanks for any feedback I get.
Does it mostly do it when the car is up to temperature? Sounds like a starter is going south. If thats your cause do your self a favor and buy this to put on your new starter
http://www.jegs.com/i/JEGS-Performan...oductId=761406.
It will help your starter life a long life, more so if you have long tubes
Al 95 Z28
Well the heat does the damage when car is running not when the starter is in use. does that make sense? Think of it this way, When happens when your in the sun all day with no sun screen on, you get burned but you dont notice it till later on after you cooled off and you wake up from a nap in the A/C and you try and move but your too burnt.
