Hood hinge bolts
Old 10-25-2011, 12:31 PM
am_muscl's Avatar
Default Hood hinge bolts
Can anyone tell me the size of the nuts and bolts for the hood hinges? I happened to misplace mine. I need the ones that go into the hood itself and the ones that connect the hinges together. If that makes sense and anyone knows I appreciate it
Old 10-25-2011, 01:59 PM
shbox's Avatar
M8 x 1.25 is the thread for most, but if you can pinpoint the numbers in the view below, I can see if there is more info... (#13 is 30mm long, #7 is 22mm long)
http://shbox.com/1/front_end_sheet_metal_camaro.jpg
Old 10-25-2011, 03:00 PM
am_muscl's Avatar
I believe it's #13 and #7 and I'm assuming #14 is the nut? Thank you very much for the help
Old 10-25-2011, 03:13 PM
shbox's Avatar
Yeah, 14 is the nut. So, you should have what you need from what I posted.
Quick Reply: Hood hinge bolts
