Stumped on Readings
Stumped on Readings
Gotta smog my LT1 Yukon this month.
I thru the handheld on it and found 2 issues.
1. Throttle position sensor
2. Shift solenoid A
I replaced the position sensor and re flashed.
The sensor issue went away with just the solenoid A being left.
I replaced both A and B shift solenoids in the trans and checked again.
The fault still shows shift solenoid A.
Anyone have any other ideas on what could cause this?
2. Shift solenoid A
Called GM and they said that for the year that I have; 99. the connection on top of the transmission is the likely culprit.
This means that I have to drop the tranny to check some stupid plug / connector.
Why in the Hell didn't they just design the connector where you can get to it without dropping the trans.
Found a few items to look at...
http://www.bulkpart.com/Merchant2/me...-4L65Esolenoid
That appears to be both ends of the harness. Just gotta figure out which end is busted.
