Head Gaskets for High Compression/nitrous
Just curious as to what you guys are using on your higher compression nitrous motors. I didnt think the Mr G. 5716s are up to the task for a 12.4:1+ motor with a 300 shot so I ordered some Cometic .036s. I thought about the 1074s but wanted a thinner gasket.
BadBlackZee is running the Cometics (.030 IIRC with pistons .002 in the hole) for his nearly 13:1 LT1 that will see nitrous. They were recommended to him by his builder.
Village Troll
Cometic MLS gaskets are your best answer. You just have to make absolutely sure the head and deck surfaces are indeed true. If they are, it is just short of welding the head onto the block.
Village Troll
I ran them on my motor for three years. I had to replace them because they started seeping coolant. I blame that on the engine sometimes sitting for long periods of time not being started.
As many have already said, if BOTH surfaces are true and flat then cosmetics should work just fine. But alot more comes into play with head gaskets, like proper TQ of bolts or studs and making sure the head does not scuff or damage the gasket when there installed.
Anyways I concluded that I'd likely also want to do other things that are made easier by having the whole engine out if I was going to pull the heads...
ARP studs made in this millenium have an allen in the stud to screw them in and out with so, studs are an absolute no brainer.
Cometic gaskets are as well. Just make sure the mating surfaces are smooth enough that you can't feel the cuts from the mill when you run your fingernail over them.
