fuel pump shuts off and car freaks out when slowing down or at a stop
still having this problem. it's random, but it ONLY happens when i let off the gas (0% tps) to coast or i'm stopped at a light. It never happens while cruising or accelerating.
fuel pump shuts off, stalls, fuel pump instantly turns back on and i get codes for:
low res failure
icm open circuit
icm grounded
fuel enable malfunction
pcm error
pcm error (always get this code twice)
i've also gotten codes for:
blown a/c rely
tranny temp too low
maf
high res failure
(these will randomly show up with the 5 codes above)
replaced the pcm, nothing.
checked all the wiring, nothing.
replaced/upgraded the battery power/ground wires, nothing. (car runs at 14.1 volts)
checked grounds on the pcm, checked good.
checked icm/opti wiring, everything looked fine. (opti harness was replaced ~a year ago, opti is ~5month old gm unit)
i can go like a week and it wont happen at all, then out of no where it'll do it nonstop, then it'll go away again...
any ideas?
low res failure
icm open circuit
icm grounded
pcm error
blown a/c rely
tranny temp too low
maf
high res failure
any ideas?
