lt4 gasket help
lt4 gasket help
need help to buy lt4 intake runner gaskets an 58mm throttle body gaskets
what year vette did they put in the lt4 in
and where can i buy a 58mm throttle gaskets at. i usually go to tpis 45 min away but i want to see if i can get them first
What I had to do with my 58mm TB is buy a stock gasket...cut it to fit. On the intake gaskets, certain just about any early-mid 90's vette had the LT4. Knowing your setup...you will probably have to cut those to fit also.
Hows the TT setup? Still all together? Remember reading about it some time ago...sick! Its been a while since Ive been on the boards.
One source for the throttle body gasket is part number BBK 1584 and the intake gasket that fits perfectly is the GMPP 12367777. TPIS should also stock the TB gaskets you need but Jegs or Summitt should have the BBK part numbers as well as the intake gaskets.
The only weird thing is that the intake gaskets are priced individually.....you'll need to order 2 of them. I never have figured out why.
