question!!!
never mind i found it. but know for my initial problem. i have oil blow by very bad and its coming out the tb. this is a fresh motor less than 300 miles. no noises no missing vacuum, compression, radiator pressure test all good. the rings im using are total seal gapless. on the instructions it says to use a 1/16 orifice in the fresh air inlet breather hose to remove all pressure from crankcase without pulling oil into the induction system
