Which valve springs?
I have a stock motor other than edelbrock shorty headers. I found some crane cams 1.6 rocker arms and I'm wondering which valve springs to get? I looked at the Alex Springs lt1 kit but when it comes to talking about the lift, etc. I have no clue about that stuff. Thanks
This will tell you a lot about valvetrain, springs, cams etc
https://ls1tech.com/forums/lt1-lt4-m...ion-guide.html
https://ls1tech.com/forums/lt1-lt4-m...ewbie-faq.html
The Alex springs will work great for a stock to small aftermarket cam. A great improvement over stock springs.
LS6 yellow springs would be good. Seat pressure's around 90lbs (550 max lift)....close to perfect! I do have a set of beehive 80lbs springs for ya that will work great, though, I'd have to see if I still have them...hehehe Dont forget about the retainers too, which are NOT the same as the LS versions so. I forgot the part number for them...
