Mcleod or Quicktime bellhousing (LT1)
Any experience with fitment of either of these? I posted this in the manual trans section but got no response from anyone that had actually used either piece.
Either the throw out bearing or the fork broke in mine and hearing the pieces rattling around in the stock housing made me think I should put an SFI piece in when it's apart.
I have a Mcleod Street Twin and was wondering if either of these would eliminate having to shorten the pivot and grind the fork like had to be done with my stock bellhousing.
McLeod SFI cert. here, no complaints the fit to the engine and trans was same as stock. Only thing I had to do was clearance some for the starter and I cut a little away from the bottom corner to allow easier acess to the drain plug on my 7qt Moroso oil pan (it comes straight out the back).
