Should I Pull Engine?
I bought a 1997 WS6 M6 thats bone stock with 107,000 miles. It has so much oil on the front of the motor including opti, I cant tell if it is just the intake or intake and timing cover gasket or gaskets. I tried to get it as clean as possible but there was just too much oil. The oil pan also looks to be leaking in the rear some. I had a clutch installed 4 months ago and the rear seal was replaced, or at least they said they did. I have pacesetter long tube headers and ORY to install along with a magnaflow catback. Do you think with all of this to do it would be worth pulling the motor and tranny, fixing my leaks, installing my parts, and rolling it back under or working with motor in. I will have to recharge AC if I pull but oil pan and rear seal would be a breeze. I have pulled LT1's before so I am leaning toward pulling but would really like to hear some opinions. Thank you for any advice.
I wanted to make sure I was being clear on the work I need to do.
I have to pull intake and reseal it.
I have to remove egr and air for headers.
I have to remove exhaust manifolds and pipes for headers and catback.
I have to pull front cover and install all three gaskets and seals,
I have to replace the oil pan gasket which is what makes me lean toward pulling the engine. After I loosen the k-member bolts and pull motor mount bolts to lift the engine enough to remove the pan, its almost pulled. I do not like trying to replace oil pan gaskets without pulling the pan because of all the crap that falls in the pan when you scrape the old gaskets.
I also do not know if the transmission shop installed the felpro rear seal I ask them to, so if I need it, I have to pull engine or drop tranny.
I respect your opinions very much and thank you for the replies, I just wanted to make sure I was clear on what I need/want to do. Thanks for your help.
