lt1 cam bearings? Help
what bearings do I get? My buddy is rebuilding his from the garage and needs to know what brand and size to get?
I told him standard sbc bearings but Idk even if that is correct since there are so many out there.
part numbers would be greatly appreciated. ITs a stock lt1 that he installing new bearings into. He would like good bearings not some junk
thanks
thanks
Just about any SBC bearing will work. http://www.summitracing.com/search/M...bearings&dds=1
Make sure you orient them correctly and use a cam bearing tool.
