280 xfi cam
280 xfi cam
Hello fellow lt1 owners I'm in the process of rebuilding my motor due to a spun bearing.I'm gonna do I cam swap since the motor is out and completely apart.I currently have long tubes,373 gears,k&n intake, and a 58mm throttle body the car is a six speed.I'm getting the stock heads ported as well as the intake I will be upgrading to bigger injectors and Walbro 255 fuel pump.I called up comp cams and was told to go with the 280 XFI cam.is this a good enough cam or is there better for my setup? Any advice would be greatly appreciated
