Vortec Distributor Reliability
I'm the original owner of a '98 C1500 with 350 Vortec. 110k on the original distributor, changed cap and rotor once. The truck runs Great. I work with a guy with a '97 K1500, same engine and the only problem he had with his distributor is when he used a aftermarket cap and rotor for a tune-up. Within a short time it started running bad, he went with a new ACDelco cap and rotor-no more problems. I learned from his misfortune and installed a ACDelco or Delphi cap and rotor when I did mine.
I've seen very few cam sensor failures with the vortec distributor (I tow for a Chevy dealer). Besides if it does fail, you can replace the sensor without removing the distributor. It may not be easy in an f-body but it shouldn't be impossible. I would say go for it. I was actually planning similar if I go with a single plane intake, and a 24x conversion.
97, aftermarket, cam, caps, distributor, distributors, fails, generation, good, pic, problems, review, running, signal, timed, vortec
