Vac line relocation?
aything is possible, not sure if its been done or why you would need it done though, maybe if you don't have egr or air you could make a block off plate with a nipple to attach the hose to?
I have seen someone on one of the forums weld up all the vac line holes on the sides of the intake and weld a few bungs to the back for connections. I think the EGR block off would be a good place to go w/o having to pull the intake off for welding.
