MSD Opti Carnage
Not yet, i would never run one with an opti anyways. It probably did pull a bit of vacuum. I can get my sheet-metal intake to flex when the throttle is opened up. I had it hooked up to a small fuel filter running thru two check valves so I didn't think it would pull that much vacuum.
I'm never going to run another opti on both my lt1s, my 94 was the only reason i did. When the opti comes back I'm going to sell them both.
I haven't measured but if a opti has a 6 inch dia, that works out to 28 sq inches of area x a differential pressure of even 6psi (assuming the hose doesn't collapse) = 168 pounds of pressure on the opti cap. You can see why its important to have good venting into and out of the opti.
