no injector pulse on 95 z lt1 PLEASE HELP !!!!
95 z lt1. I bought the car not running. I thought it had a vats problem so I sent the computer off and had it deleted. I also had the air pump and egr deleted. The car will start up 3 or 4 times. Then it will die and won't restart. I put injector noids on it and no signal. I tested power at the fuses none. I pull the fuse and I have power with a multimeter. Put the fuse back in and no power. If I let the car sit overnite it will start right up 3 or 4 times. then it start its problem all over agian. I have spark and 42 psi fuel pressure. I'm out of ideas. PLEASE HELP.
