95 Camaro z28 code 32 egr fault need help please
hello,
I have a obd1 95 Camaro z28 and it had a code 32 which is egr problem. But I have inspected the egr it holds vacuum when tested and egr lines are fine and wondering if it could be the electric control solenoid for egr?
Any help would be great.
Thanks everyone
Thanks everyone
32 is for EGR operation-not electrical malfunction. There is another code for that. The PCM is not sensing that the valve opening is causing the required result. Did you pull the valve off and check for carbon build-up?
