24x leftover pins?
24x leftover pins?
Ok guys my harness is from a 1996 M6 car and i am left with black 5,14,23. blue 3,10,15,20,24,30. clear 11. and red 9,12,14,23.
Black 23, Blue 10, 15, 24, Clear 11, Red 9, 14, 23 all deal with emissions and traction control so can they just be deleted?
And heres my list of what went where.
Black connector lt1 pins.
lt1 28-ls1 blue 8
lt1 30-ls1 blue 19
lt1 15-ls1 blue 20
lt1 29-ls1 blue 45
lt1 6-ls1 blue 60
lt1 16-ls1 blue 54
lt1 31-ls1 blue 57
lt1 13-ls1 blue 79
lt1 3-ls1 blue 21
lt1 2-ls1 blue 73
lt1 20-ls1 blue 61
lt1 21-ls1 red 18
lt1 19-ls1 red 31
lt1 8-ls1 red 50
lt1 1-ls1 red 17
lt1 red connector pins
lt1 19-ls1 blue 3
lt1 21-ls1 blue 4
lt1 1-ls1 blue 12
lt1 3-ls1 blue 36
lt1 5-ls1 blue 37
lt1 11-ls1 blue 42
lt1 4-ls1 blue 43
lt1 6-ls1 blue 44
lt1 20-ls1 blue 76
lt1 22-ls1 blue 77
lt1 18-ls1 blue 40
lt1 2-ls1 blue 1
lt1 7-ls1 red 9
lt1 13-ls1 red 10
lt1 31-ls1 red 20
lt1 32-ls1 red 21
lt1 25-ls1 red 30
lt1 10-ls1 red 33
Lt1 CLEAR
lt1 17-ls1 blue 25
lt1 7-ls1 blue 26
lt1 3-ls1 blue 28
lt1 19-ls1 blue 29
lt1 18-ls1 blue 65
lt1 8-ls1 blue 66
lt1 4-ls1 blue 68
lt1 20-ls1 blue 69
lt1 25-ls1 blue 74
lt1 32-ls1 red 1
lt1 22-ls1 red 24
lt1 21-ls1 red 25
lt1 23-ls1 red 32
lt1 6-ls1 red 76
lt1 5-ls1 red 77
lt1 2-ls1 red 78
lt1 1 -ls1 red 79
lt1 blue connector pins
lt1 22-ls1 blue 51
lt1 7-ls1 blue 58
lt1 12-ls1 red 14
lt1 1-ls1 red 40
lt1 8-ls1 red 43
lt1 6-ls1 red 44
lt1 blue 9-ls1 red 46
lt1 28-ls1 blue 8
lt1 30-ls1 blue 19
lt1 15-ls1 blue 20
lt1 29-ls1 blue 45
lt1 6-ls1 blue 60
lt1 16-ls1 blue 54
lt1 31-ls1 blue 57
lt1 13-ls1 blue 79
lt1 3-ls1 blue 21
lt1 2-ls1 blue 73
lt1 20-ls1 blue 61
lt1 21-ls1 red 18
lt1 19-ls1 red 31
lt1 8-ls1 red 50
lt1 1-ls1 red 17
lt1 19-ls1 blue 3
lt1 21-ls1 blue 4
lt1 1-ls1 blue 12
lt1 3-ls1 blue 36
lt1 5-ls1 blue 37
lt1 11-ls1 blue 42
lt1 4-ls1 blue 43
lt1 6-ls1 blue 44
lt1 20-ls1 blue 76
lt1 22-ls1 blue 77
lt1 18-ls1 blue 40
lt1 2-ls1 blue 1
lt1 7-ls1 red 9
lt1 13-ls1 red 10
lt1 31-ls1 red 20
lt1 32-ls1 red 21
lt1 25-ls1 red 30
lt1 10-ls1 red 33
Lt1 CLEAR
lt1 17-ls1 blue 25
lt1 7-ls1 blue 26
lt1 3-ls1 blue 28
lt1 19-ls1 blue 29
lt1 18-ls1 blue 65
lt1 8-ls1 blue 66
lt1 4-ls1 blue 68
lt1 20-ls1 blue 69
lt1 25-ls1 blue 74
lt1 32-ls1 red 1
lt1 22-ls1 red 24
lt1 21-ls1 red 25
lt1 23-ls1 red 32
lt1 6-ls1 red 76
lt1 5-ls1 red 77
lt1 2-ls1 red 78
lt1 1 -ls1 red 79
lt1 22-ls1 blue 51
lt1 7-ls1 blue 58
lt1 12-ls1 red 14
lt1 1-ls1 red 40
lt1 8-ls1 red 43
lt1 6-ls1 red 44
Black Connector
5- Ignition Control
14-Distributor Ignition Feed
23-EVAP switch feed.
None of these are used.
Blue Connector
3- PCM Ignition Feed
10- EVAP Canister Purge
15-Skip Shift Lamp Control
20-Output Service Enable
24-Evaporator temp signal
30- Serial Data
Blue 3 could have been used in Blue 19 but you used the other ignition there. So it can be deleted, remember there is 12v there so delete it properly. Provided you do not want the skip shift all of these can be deleted.
Clear
11- Traction control active signal.
This will be deleted.
Red
9- EGR Vacuum Signal
12-BCM TPS Signal
14-AIR Pump Relay Control
23-Traction Control Spark Retard
These get deleted also, these LTX emissions are not compatible with the lsx pcm.
Good Luck
Bill
BP Automotive
5- Ignition Control
Blue Connector
30- Serial Data
Clear
Red
12-BCM TPS Signal
Good Luck
Bill
BP Automotive
lt1 blk 2 is red/blk wire 453 low resolution signal
lt1 blk 20 is ppl/wht 430 high res sig
ls1 blue 61 is cam position sensor low
ls1 blue 73 is cam position sensor signal
this is what i have.
I just am confused as to what I should do with the black 2 and 20 I have pinned in the ls1 blue 73 and 61 if the cam position sensor pins belong there.
Again thanks guys this is my first time repinning any wiring and everything went smooth and has been going smoot just hit one small snag.
you have the diy kit so thats where those wires go. you just delete the 2/20
cam sensor wireing:
red wire-red 39
pink wire-blue 61
brown wire-blue 73
crank sensor wireing:
light green wire- blue 2
blue wire- blue 2
yellow wire- blue 21
cam sensor wireing:
red wire-red 39
pink wire-blue 61
brown wire-blue 73
blue wire- blue 2
