made my own ls coil mounts pics in
thanks! still have to clean up the flat stock then paint. I did mess up the driver side lol. didnt mark top n bottom. took em to work to weld them put the center stud on the top n not the bottom. coil harness plug is rite there had to cut it off and put it on the bottom. after paint and the coil brkt installed you can't see anything that i did anyways.
