Lt1 exhaust project
Lt1 exhaust project
Hey guys, I've been looking to upgrade my exhaust on my 93 Trans Am, and sorta have a plan put together, but I figured I might as well consult the infinite wisdom of the internet first. Just wanted to get opinions/advice/etc. So here's the plan:
-Pacesetter longtubes and ORY
-DMR cutout in place of stock cat
-keep the rest of the stock pipes (behind the cat)
-Hooker Aerochamber muffler and quad tips?
I'm most concerned about what muffler I should get. I really don't mind if it's loud, I'm currently running the car without a muffler at all due to unforseen circumstances and I don't particularly mind the noise. But I would really like a good looking, awesome sounding muffler that I can weld right on to the stock 2.5" muffler inlet, and find some tips/mandrel bends for behind it and make it look good and sexy.
I'm turned off to the idea of paying for a whole catback when I can get basically equivalent sound with running it through the muffler, and I can open the cutout when I feel like waking up the neighbors. I also daily drive the car and have to deal with parking garages, curb driveways, etc so I really don't want to be scraping all the time with some expensive 3.5" pipe catback. Any thoughts/concerns/advice is much appreciated, or if you know of any muffler set up that you think would work for me do let me know! I'll of course post pics once it's all done.
93 Trans Am M6, AC delete, CAI, CC stage 3 clutch, mostly stock otherwise
Or just go with the Hooker Aerochamber muffler. It's perfect. Here's a link to my 383 running through the Hooker at idle:
That does sound pretty sweet... I also have a welder and a pipe bender and hate the idea of having anyone else work on my baby, so I'll do all the fabricating myself. But I will look into it and weigh the options again... I'm still leaning towards leaving the stock piping and cutting out the cat to weld in my cutout. I'd just weld in the muffler to the inlet as well. I'm assuming you have the whole hooker catback, including the muffler?
Gotcha. What cutout do you run? I'm looking into DMH (typo in my original post), the consensus seems to be that they know what they're doing.
I got a similar setup, Hooker catback with Pacesetters long tube headers and ORY pipe. I love it! Sounds quiet and mellow at idle and nice muscular sound under load. No rasp either, just perfect. Highly recommended.
Nice, I'd love to get a Hooker setup from headers to muffler but unfortunately its just not in the budget. I've heard good things about pacesetters though, and you really cant beat the price. I'm still deciding between the muffler alone and the full catback.
Keep in mind that a lot of guys on here run the "summit brand" headers, which are essentially pacesetters rebadged with the summit name. Could save you a few bucks to put somewhere else in your project
On another note, does anyone have experience with the black painted long tube headers? The ones I'm looking at
from pacesetter and from summit both have the black finish, and I'm nervous that the paint will look like crap after enough heat cycles compared to the silver ceramic finish. Any thoughts or experiences?
It's just black paint to keep them from rusting on shelf. It will burn right off. Get the coated unless you want bare rusty header pipes. Get a 3 inch cutout. If you want to keep your stock catback go for it. The inlet at the over axle pipe can easily be expanded to 3. Mellow closed and loud if you want it. Or if you are looking for a little more sound with it closed you could install an aftermarket muffler in place of stock since you will have a cutout no need to worry about pipe size and mandrel bends.
With any decent amount of street use even ceramic coated headers will rust. The coatings primary purpose is NOT for aesthetics but to retain the heat and keep exhaust velocity up.
If you want the benefits of the ceramic coating AND to keep them looking new I would go with a stainless steel header. Maybe wait for the LPPs to come back out (whenever that might be).
