Engine swap, does nothing when i turn the key
Old 02-03-2013, 11:44 AM
sherman8r's Avatar
Default Engine swap, does nothing when i turn the key
95 z28 just swapped motors and nothing happens when i turn the key. dash lights come on as normal but i don't here the fuel pump and starter is quiet as a mouse, not even a click. I sent the pcm to pcm4less and it should have vats removed but i haven't done anything to the car itself to remove vats. Ive checked all the fuses and im kinda stumped. looking for suggestions.
Old 02-03-2013, 11:54 AM
shbox's Avatar
LS1Tech 10 Year
What is the status of the security lamp?
Old 02-03-2013, 12:14 PM
sherman8r's Avatar
security lamp isn't lighting up at all. btw your website saved me a lot of time and trouble and i would like to thank you for that.
Old 02-03-2013, 12:37 PM
sherman8r's Avatar
A video so you can see exactly whats going on. I found this connector that has no home and i must have forgotten to mark it, any idea what it goes to
Old 02-03-2013, 12:43 PM
F0x Slaughter's Avatar
Just so you know that video is private.
Old 02-03-2013, 12:45 PM
sherman8r's Avatar
Thanks, should be good now
Old 02-03-2013, 12:52 PM
The power being cut when you try to start seems like a VATS issue to me.Pretty sure that purple connector goes to the ABS module, I just looked in my car. Mine is removed so I think thats what its too.
Old 02-03-2013, 12:56 PM
sherman8r's Avatar
Originally Posted by F0x Slaughter
The power being cut when you try to start seems like a VATS issue to me. That purple connector I'm pretty sure goes to your MAF sensor.
MAF already plugged in. Not part of the engine harness itself it comes from that large group of wires on the driver side frame rail area.
Old 02-03-2013, 12:57 PM
Yeah sorry, I just edited my post.
Old 02-03-2013, 01:01 PM
sherman8r's Avatar
any good way to see if its a battery issue? new red top optima and i cleaned the connections.
Old 02-03-2013, 01:04 PM
Spartan7's Avatar
That connector looks like the AIR pump. Hard to tell, but your car is manual, right? Could be a bad clutch start switch.
Old 02-03-2013, 01:07 PM
sherman8r's Avatar
yea m6, know how to check the clutch switch?
Old 02-03-2013, 01:09 PM
Could be the AIR pump also haha, mine is also removed so I just have connectors laying around.
Go point on the clutch switch. When you depress the clutch one of the wires on the switch should see 12v.
Old 02-03-2013, 01:10 PM
Spartan7's Avatar
Simple. Unplug it (flat black switch mounted under clutch pedal) and short the 2 pins with a short section of wire or something. That will bypass the switch. If it starts, bad switch.
ZFreie's Avatar
Check all your grounds?
Hard to tell from the video but I don't think I hear the starter trying to engage either? Double check that as well?
Also agree with the AIR pump connection, just went and checked on mine, and its the same
Old 02-03-2013, 01:18 PM
sherman8r's Avatar
jumped the switch and still no crank
Old 02-03-2013, 01:20 PM
Spartan7's Avatar
Your battery gauge reads below 8. Does it work? Could just be a really dead battery. See if your headlights are really dim. Put a multimeter on the battery posts too, check the voltage.
Old 02-03-2013, 01:22 PM
sherman8r's Avatar
that's right no sound from starter or fuel pump. i will double check grounds on the driver side rail near the air filter and starter area that's all there are right?
Old 02-03-2013, 01:26 PM
sherman8r's Avatar
Good eye i failed to notice that. pretty sure it worked it worked before the swap. battery shows 12.14 at the terminals
Old 02-03-2013, 01:31 PM
ZFreie's Avatar
I'm not sure on # of grounds, someone else will have to jump in to be sure.
Also, all fuses are good?
If it were my car I would be trying to figuring out why the starter isnt trying to engage and go from there.
Quick Reply: Engine swap, does nothing when i turn the key
