Broken wire by passenger O2?
Old 02-18-2013, 02:40 PM
porksoda's Avatar
Default Broken wire by passenger O2?
Ok so I changed my O2 sensors today and noticed a broken wire coming out of the loom along with the 4 O2 wires and single knock sensor wire. This is on the passenger side and I can't seem to find anywhere the single broken wire would go? The 4 O2 wires are intact as well as the knock sensor. The broken wire in the pic is black with a single white line.
Old 02-18-2013, 03:45 PM
stevo9389's Avatar
i think that is a ground wire. mine was connected to one of the oil pan bolts
Old 02-19-2013, 02:11 AM
Spartan7's Avatar
PCM ground on the block.
http://shbox.com/1/g103.jpg
Old 02-19-2013, 08:15 PM
porksoda's Avatar
Yea I found it after some extensive searching. A stud behind my header primary that is nearly impossible to reach without a variety of wobbles, extensions, and swivels. I also searched amd looked all over shbox...apparently I just looked in the wrong places.
Quick Reply: Broken wire by passenger O2?
