1994 camaro lt1 swap with a 1995 lt1
Old 02-24-2013, 11:19 AM
zlow6869's Avatar
Default 1994 camaro lt1 swap with a 1995 lt1
ive got a 1994 Camaro and im debating about swapping out the motor instead of re building. I have a 1995 lt1 that is good, and im just wondering if everything will plug in and work ?
Old 02-24-2013, 12:32 PM
RamAir95TA's Avatar
For the most part everything will swap over. There's nothing on the 94 that you can't use on the 95 motor. It also depends on how much you're swapping in (harness, accessories, etc.).
Old 02-24-2013, 03:41 PM
zlow6869's Avatar
I know the 95 has a different style opti so the main thing I was wondering is if all of the connectors are the same that way I wouldn't have to change the harness
Old 02-24-2013, 05:25 PM
shbox's Avatar
You just need to use the opti harness that is on the 95. It will plug in to your 94 harness fine.
Old 02-24-2013, 07:19 PM
zlow6869's Avatar
ok thanks also I have a 93 lt1 that I pulled from a cop car I know it has iron heads and different accessory brackets would the b body lt1 work if I decided to use it
Old 02-24-2013, 09:24 PM
shbox's Avatar
The basic engine will work...maybe not as easily as the 95 you mentioned (if out of an f-body), but still doable.
Quick Reply: 1994 camaro lt1 swap with a 1995 lt1
