Finishing up 24x DIY Wiring, just a few wires left
I have a 97 Trans AM with T56
1. Where should I get the 12v wire for LS1 Blue 2 for the Crank sensor.
2. LS1 Red 15 Alternator L Terminal--do I need to put anything here? The sheet has this wire blank on the LT1 side.
3. LS1 Red 57, LS1 Blue 54, LS1 Blue 60 and LS1 Blue 80 are grounds and I have LT1 Black 6 and LT1 Black 16 for grounds. Where should I get the other 2 grounds? Just run ground wire from the block to the 2 leftover sensors themselves?
4. LS1 Blue 11 Knock Sensor 2--I am assuming I leave this empty since I am only using one knock sensor.
5. LS1 Blue 19 calls for LT1 Black 30 and Black 3, do I just need to use one or the other of the LT1 black 30 or black 3 and remove the other?
6. LS1 Blue 45 and 48 both need 5v, I have LT1 black 29 going to one. Where do I get a 5v reference for the other?
Thanks
Tim
Thanks
Tim
