Lt1 spark advance
Old 04-17-2013, 11:44 AM
jrwilliams95z28's Avatar
Default Lt1 spark advance
Hey I'm just wondering what people are getting at WOT on a close to stock setup. My lt1 would get knock retard at anything above 28* in the 4000-4800rpm range and above that I can get around 31*.
This is with a 13.5:1 AFR. I always run 94 octane is this normal for it seems low compared to some other LT1's but the distance/time calculator on datamaster says its doing 0-60mph in 5.4s which is good.
Originally I thought it was false knock because it kept yapping at the same rpm but after dropping my spark advance to 28* in that area and desensitizing the knock sensor a bit it's eliminated it completely.
Just wknte
Old 04-17-2013, 01:57 PM
nitrous2fast's Avatar
13.5:1 Is on the lean side for making good power. Generally speaking LT's tend to make best power from 12.7-13.1:1. That could be part of the reason you are dealing with spark knock.
Old 04-17-2013, 06:42 PM
good point, you think it would be lean enough to cause that much knock?
Old 04-17-2013, 09:06 PM
96capricemgr's Avatar
I would agree on the AFR, that is a dyno number AFR not a max performance AFR. As I believe I have told you before though with the MSD opti the only way you know what timing is would be a keyed hub a timing pointer and at least a TDC mark.
Old 04-18-2013, 06:40 PM
wings66's Avatar
Just wknte
how did u adjust ur spark advance?
Old 09-12-2013, 10:28 AM
Tunercats
Old 09-17-2013, 04:39 PM
pumasixtynine's Avatar
You can do a knock sensor mod, its free and you can google in on how too. Only thing is? You have to put premium gas in it from that point on!!!
Quick Reply: Lt1 spark advance
