93 lt1 firebird need help
ok so I started a post before but im still having issues I keep burning up ignition modules now I need help trying to figure out why its doing this anything would be great
first thing my security light stays on I can start my car without the pill in the key/wires hooked up also my air pump went out so I just hooked the hose to the ram air box so its constantly sucking air I just replace plugs wires and msd cap and rotor ive gone thru 3-4 ignition modules im getting 12v to the icm like it should ive I checked resistance in the coil everything checks out fine I have a code for the air pump think its code 26 dk if its setting the computer telling it its running lean/rich so if anyone has so info I greatly appreciate it
Ok i got my security taken care of i put resistors in and solder it under colum now i am only getting 5v to the ignition module is that bad or and ideas where i should start next
