96 camaro ss wiring
96 camaro ss wiring
ok so my buddy bought a 1996 camaro ss and somebody else put aftermarket headers (SLP) an intake(SLP) a radiator and two aftermarket gauges- regardless the belt shredded and tore off the wiring for coolant temp sensor under the waterpump and now i cant locate the harness that it came from and it is a 3 wire sensor. Also there are two connectors up top that im having trouble identifying one is obv for the IAT sensor not sure of the other one tho so does anyone have wire colors and locations because this thing starts REALLY hard and i wanna do EGR and AIR deletes but i wanna get it running properly first- pics and advice would be appreciated
IAT and that water pump temp gauge i believe are in the same little harness that stretchs off the side there.. might even stretch off perhaps IAC and the TPS harness right there.. id have to look but thats my guess off the top of my head
on my 94...the cts wiring is routed (from the sensor) across the front of the pump and to the harness section between the throttle boby and alternator. To the ecm from there.
The only lt1 cts's iv seen are 2 wire but i have heard of a 3 wire that runs the temp guage aswell. Never researched it so not sure. There are several sensors in the area so to idendify the other 2 plugs a pic or description of the plugs is needed.
http://shbox.com/1/harness.htm
http://shbox.com/1/1995_pcm1.jpg
http://shbox.com/1/1996_ec_03_ign_system.jpg (crank position sensor is probably your 3 wire connector) The previous links do not show it, because it is 96 and later.
