Tunercats commanded AFR shenanigans
My %change to air/fuel vs rpm numbers are upto high 20's and low 30's. Doing the calculations my commanded afr is somewhere around 9.7 but im showing 13.1-13.3 at WOT. Is this normal or do I need to adjust something somewhere?
I had stock injectors and they just wouldnt get the afr down so I picked up some SVO redtops and made the numbers up above. Whats goin on here?
