96 LT1 into 95 Formula Firebird
Old 01-12-2014, 10:29 AM
rhmagic1's Avatar
Default 96 LT1 into 95 Formula Firebird
Need some advice. We are putting a 1996 Impala LT1 into a 95 Formula Firebird. Engine is set up with crank trigger and I know 95 didn't use it. What is the easiest way to make this wiring work. Am I going to have change the loom and computer to a 96 set up? Street / strip car.
Thanks
Old 01-12-2014, 11:00 AM
bowtienut's Avatar
You can leave all wiring and PCM as-is.
Just get a NEW stock replacement knock sensor for the 95 Formula and torque it in whatever side of the replacement engine the F-cars use. Leave the one on the other side of the 96 B-car engine in; it will serve only as a plug.
Disregard the crank position sensor on the replacement engine; it's not needed for the 1995 OBD1 system.
Old 01-12-2014, 11:32 AM
rhmagic1's Avatar
Default Thanks
Just checking, It is a LT1 from a police car that wont make any difference Correct. thanks
Old 01-12-2014, 12:14 PM
bowtienut's Avatar
Correct.
Quick Reply: 96 LT1 into 95 Formula Firebird
