just an other 24x question about ECT sensor
ok i have done some searching, i know the ls1 sensor has a different part number then the lt1 so they are physically different, but for the 24x swap do they send the same signal to the pcm?
thanks Mike, soon as the weather here in Michigan breaks i will most likely be bugging you some more, only after i do some diagnostic at a shop that has a oscilloscope thou an if i still can't figure out my no fuel no spark issue.
