lt1 rebuild help
lt1 rebuild help
I have a few questions if any one could answer a few be grateful
1) stock pushrod length is 7.195" and comp recommends 7.2 should I change my push rods?
2) do I need to change the locks when changing out the springs and retainers and seals?
3) is taking off the optispark and putting back on hard any suggestions?
4)im having an issue with the SES light it only comes on when im driving or cruising goes away when im idol
5)my car has long starts and has to be primed every start up I have heard it Is the check valve is that something that comes with a new fuel pump
6) my gas guage has like problems 20 dollars fills it to f and a fill up spins all the way to the plastic is it the fuel level sending unit?
