TPS voltage going up and down
I hooked up my laptop to my 95 LT1 and noticed that the TPS voltage reading while at idle keeps bouncing up and down by about .2 (.30 - .50 or so). The % also keeps going up and down between 0% and 4%. It won't stay at an exact number. Could that be a problem causing my IAC valve not to operate properly? Because the car idles very high usually.
I just replaced the TPS sensor, but it still fluctuates between 0,1,2, and 3% at idle, without touching the throttle. Even with the car off the voltage fluctuates within a .10 range. What could be causing this?
Is everything else good? Battery charging correctly, good battery? I have only seen this one time on a turbo pt cruiser with a bad cell in the battery. But Chrysler are very finiky about voltage.
If the alternator is charging the system, it is going to be 13+ volts. If it is not, the alt is not working. Use a meter to check-don't depend on the gauge.
There can be some voltage loss through the circuitry getting to the PCM. It's a common thing. Check it with a meter at the battery. Either way, sounds like the alt is not working. Have it tested.
