mjchevy1418
Old 04-21-2014, 08:06 PM
mjchevy1418's Avatar
Default mjchevy1418
Hi all i am new to this site and did a lt1 swap from a 95 camaro into a 95 impala and all has went well except i have a very slight hesitation when i accelerate almost as if there is something clogged or a vacuum line covered . I have a replace everything from the fuel pump to new injectors to every sensor.Maf map tpc iac ...PLEASE HELP ME!!!!
Old 04-27-2014, 02:53 PM
englundjd's Avatar
welcome to the site! you mentioned that you replaced the injectors, did you get stock 24# injectors or did you get something bigger? if you did you will need a tune and that could be causing your issue. otherwise as you say it could be a vacuum line. Also are you getting an ses light? If so you need to scan the pcm
Quick Reply: mjchevy1418
