Left & right bank upstream o2 sensors reading inactive
Hey guys I need your help here. A little bit about the car, long tube headers, ory pipe, downstream o2 tuned out. Car was performing great but had the passenger side header gasket was leaking causing an exhaust leak. I took the car to race shop they pulled both headers off milled both headers put copper gaskets on and sealed the exhaust ports with copper oppoxy. Locking header bolts installed. No more exhaust leak. Car was running great drove it for about 40 miles and put it away in its storage garage. Last week I go and start the car, and the check engine light comes on. I took the car to advanced auto to pull the code out. Scanners states right and left bank o2 upstream sensors inactive. What could cause both to have no activity? I look for any wires hanging to see maybe a wire got burned but seen nothing to prove that. Engine fuse is not blown. So I'm stuck on this one. Could both o2 sensors just be bad? It just seems odd that they both read no activity.
Village Troll
What exactly is that? Permatex? If so, was it Ultra? If it's not sensor safe your O2's could be gummed up. There is never any good reason to use sealant on exhaust parts, ever. All it will do is blow out over a short period of time if there is the slightest amount of exhaust leaking.
The slip joint in my hooker long tube headers was the route of all my problems. Was able to get a clamp around the joint which solved the exhaust leak, which was causing the o2 sensor in the driver side to run lazy. I hope this thread answers any problems for guys in the future. On a side note this winter the lt1 pcm is coming out and the 24x conversion is going in. Matt at tune time performance here in nj (his corvette was featured in this months super chevy) will then be deleting the upstream o2 sensors. So I'll be running totally off the maf sensor.
