1994 camaro lt1 grinding when starting
Old 06-02-2014, 10:05 AM
lt941's Avatar
Default 1994 camaro lt1 grinding when starting
Hey guys i have a 1994 Camaro Lt1 with a 6 speed and lately i've been hearing a grinding or coughing sound when i start it. it doesn't happen all the time and only does it while its still cranking and not after it has started and only lasts for a couple seconds. there are no noises after it has started and runs fine after that. I've been searching for a while and cant seem to figure out what the problem is. Any and all help is greatly appreciated.
Old 06-02-2014, 10:29 AM
shbox's Avatar
To begin with, check that the starter is not coming loose.
Old 06-02-2014, 11:14 PM
tricked94camaro's Avatar
weak starter, shim the starter, etc
Old 06-03-2014, 04:20 PM
lt941's Avatar
I checked the starter and it appears to be tight. It seems like it does it a lot more after i stop and shut it off and get back in again like if i got gas, shut it off and where to start it, it would make the noise again.
Quick Reply: 1994 camaro lt1 grinding when starting
